Advice needed on reverse alarm
Discussion in 'The Projects Forum' started by 0Hz, Jan 11, 2013.
Thread Status:
Not open for further replies.
  1. 0Hz
    Sep 4, 2012
    Sorry if this is a stupid question, but I'm pretty new to electronics.
    I have a 90db piezo buzzer that I wanted to use to make "quick & dirty" reverse, or backup alarm for my dad's truck. My first idea was to just use a thermal turn signal flasher in series with the buzzer, but that doesn't work. I assume that it is because of the fact that the buzzer only draws ≈20mA and that this is not enough to trigger the flasher, because the buzzer is just on continuously when the truck is in reverse. But I could be wrong about that...
    Anyways, is there any thing that I can add to to load on the flasher that will draw more current safely and cause it to start turning on and off? Thanks for the insight.
  2. MrChips
    Oct 2, 2009
    12,635
    3,454
    I think you got the wrong buzzer. There are pulsating buzzers that do that when 12V continuous is applied.
  3. 0Hz
    Sep 4, 2012
    That's what I thought too, and this is one of those "Pulsing" buzzers, but the "pulse" mode is so fast that it's really just like a different pitch.
  4. tubeguy
    Nov 3, 2012
    1,157
    197
    Why not just wire in an automotive turn signal lamp ?
    (or two if one blinks too fast)
  5. 0Hz
    Sep 4, 2012
    That's a good idea. I ended up realizing that I had enough parts to make a circuit using a 555 timer instead. Thanks for the advice though. In case anyone wants to know, I found that when driving a piezo from a 555 in astable mode, to make a very clean "on, off" sound rather than a sort of modulated pulse (never fully off), make sure to sink the current for the piezo (i.e. connect the negative terminal of the buzzer to the output pin of the 555).
  6. Georacer
    Nov 25, 2009
    5,151
    1,266
Thread Status:
