Advice Needed : MAX7219 driving 5 Led Dice
Discussion in 'The Projects Forum' started by Netfrog, Oct 25, 2012.
  1. Netfrog
    Oct 22, 2012
    6
    Hi Folks,
    I'm new to electronics and new to AllAboutCircuits. I started dabbling with Arduino a bit (3 months ago) and decided to create a project to roll and display 5 led dice. I created this project to enhance it later to create games like Yahtzee or Farkle and other similar type dice games.
    However, I need to start with a display for 5 dice. I'm providing a wiring diagram for my project and would like to get some advice on it.
    In essence, I'm treating each die as a column and each spot per die as a row. Therefore, I'll have 5 colunms (5 dice) and 8 rows (7 for each spot per die plus one left-over for use as an indication led).
    My thought was that if a MAX7219 can drive a 8x8 led matrix, then it should be able to handle 40 leds. The LED matrix will be driven by an Arduino.
    I'm hoping I created/designed the wiring diagram properly but just in case I'm throwing this out there for help/constructive criticism.
    Thanks!
  2. Netfrog
    Oct 22, 2012
    6
    Nevermind ... Went ahead and put it together ...
  3. tracecom
    Apr 16, 2010
    3,878
    1,396
    With good results, I hope. Do you have pictures?
  4. Netfrog
    Oct 22, 2012
    6
    Hi Tracecom ... Worked like a charm! However, since this was my first try at it (and soldering), the five dice are too close to distinguished them as dice and of course my soldering skills leaves a lot to be desired. Also, I used clear bright leds which did not give the desired effect I was looking for.
    Because of this, I'm going to forego showing a picture of it.
    However, I am going to do another one with the proper white leds (diffused) and more spacing between the dice (group of leds) to distinguish them as dice.
    Since this mini project is led based, would a posted video (YouTube) be a better option to show it working rather than a picture/photo? (A link to the video of course).
    Netfrog
  5. tracecom
    Apr 16, 2010
    3,878
    1,396
    I like to see photos and videos of members' projects.
  6. Netfrog
    Oct 22, 2012
    6
    Hi Tracecom,
    Sorry for the delay. I just recorded the video from my Android phone and posted it on YouTube.
    You can see it here :http://www.youtube.com/watch?v=TyGYZJqDVMA
    Let me know what you think ...Sorry about the brightness of the led display. This is my second version that I put together. Much better than my first one! I made a second video using a paper filter but I haven't uploaded that one yet.
    Dave
  7. tracecom
    Apr 16, 2010
    3,878
    1,396
    Looks good. Is this a hobby project or do you intend to use it commercially?
  8. Netfrog
    Oct 22, 2012
    6
    Thanks!
    Well ... it's starting out as a project! As I dabble more into this I'm visualizing other things can do with this.
    Here's another video ...
    http://www.youtube.com/watch?v=ICKSoPDwpGE
    I actually rolled the MAX! lol ...
    Dave
