I need to remove the wires from this board
http://imgur.com/a/FCl36
I see a small "box" next to one of the wires. Will that be removed when desoldering the wire?
On the side with the bulbs there is a hole with a negative sign. Is that the black/negative wire?
I will take the two wires from this board and solder them to the above board.
http://imgur.com/a/yUAWi
I have a solder and desoldering wick, I have never used them before.
