Hi everyone,
I'm new to the board and trying to devise a scheme for some effects I'm trying to do for some LED rope lighting that is a part of some accent lighting for outdoor decorations I'm doing.
I used to know circuits pretty well and studied EE in college but a decade in power distribution hasn't been kind to my ability to recall the intracacies of building my own custom circuits. I'm hoping a little advice and friendly discussion might bring me back.
Anyhow, what I'm trying to do is create a trigger/flasher/timeout combination circuit that when triggered will produce an output to a relay to 'blink' three times and then return to an "on" state until re-triggered. In other words, I would like for the lighting to be on until someone walks through, upon activation blink three times, and then return to being steady on again. If a normal 'low' output circuit is easier or less complicated I can always flip flop the output based on whether I use a n/o or n/c output relay so the actual output of the circuit being high or low normally isn't as much of a concern as the blinking and timeout functions.
My input will be from a 12v battery which will power a 12v infrared optical sensor (similar to garage door safety beams) through this circuit. Thus it will require fairly fast and moderately sensitive trigger as I need it to be quick enough to pick up an ankle passing through the beam at average walk/run speed. Once it is triggered by the sensor I want the circuit to blink 3 times (at approximately 0.5 seconds each) and then return to "on" state.
One catch is that I was hoping to use a spare set of garage door sensors that I have for this project. The sensors aren't truly a high or low output in the +12vdc or 0vdc sense. The are actually around +10vdc and are active high at +12.5vdc when the beam is broken. I'm not sure if this would affect the trigger chip for the circuit.
I know I'm a newbie to the forum and any help would be greatly appreciated. This is definitely one of those times when I wish I hadn't sold so many books back at the end of the year in my school days, but thanks for any help and advice!!
