Advantages of FPGA
Discussion in 'Embedded Systems and Microcontrollers' started by rockisforkids, Jan 18, 2010.
  1. rockisforkids
    Jul 19, 2007
    What are the advantages/disadvantages of using FPGAs? Comparing to microcontrollers for example (8,16 or 32bit).
    Are FPGAs used in industry or are they used just for simulation or educational purposes?
  2. n9352527
    Oct 14, 2005
    1,198
    Speed. Parallel operations. Flexibility. Those are just several of many advantages.
    Of course, they are widely used in many industrial and commercial applications. Educational use alone will not support the scale of current FPGA market/industry.
  3. msr
    Jul 8, 2008
    62
    Can you give me examples of market products that make use of FPGA?
    Thanks for the response!
  4. arivalagan13
    Member
    Apr 30, 2009
    29
    1)Reprogrammable HARDWARE..
    2)Supports parallel processing(so finds application in VLSI signal processing)
    3)Optimization(if u want a 10-bit microcontroller 4 ur application u can design ur own)
    4)laboratory prototyping
    apart from these in our lab at IITMadras we need several digital circuits for our Haptics and mannequin project...what we r doing is we r implementing all the digital circuits in a single FPGA board,which saved us lots of time as well as hardware and cost and improved efficiency of our system
    hope this is enough...
  5. StayatHomeElectronics
    Sep 25, 2008
    864
    40
