Advantages and Disadvantages of a High Frequency
Discussion in 'Homework Help' started by David Waddell, Feb 24, 2015.
  1. David Waddell
    Dec 3, 2014
    24
    Hello
    Just looking to know what the main advanagtes and disadvanatages of a high frequency in a circuit. ( 7400 Series and 4000 Series). Just looking for some background information to my assignment.
  2. MrChips
    Oct 2, 2009
    12,636
    3,455
    At high frequency, logic circuits run faster, consume more power, generate more heat and more circuit noise.
  3. crutschow
    Mar 14, 2008
    13,502
    3,376
    What's your assignment?
    The higher the frequency, the shorter the time to process a specific digital function, with a higher frequency causing the effects noted by MrChips.
    Another problem with very high frequencies is that the PCB layout and grounding becomes more critical.
  4. David Waddell
    Dec 3, 2014
    24
    what if they run in CMOS?
  5. WBahn
    Mar 31, 2012
    18,087
    4,917
    4000 series logic IS CMOS.
  6. David Waddell
    Dec 3, 2014
    24
    not all 7400 series families are CMOS
  7. WBahn
    Mar 31, 2012
    18,087
    4,917
    So?
    You asked about 7400 series logic and 4000 series logic and you got an answer that did not distinguish between them. Since 4000 series logic IS a CMOS family, why don't you think the answer applies to CMOS?
  8. David Waddell
    Dec 3, 2014
    24
    Because CMOS circuits use less power, so I wanted to confirm that he wasn't talking generally about frequency
  9. MrChips
    Oct 2, 2009
    12,636
    3,455
    74C00 series is CMOS. Also 74HC00 series.
    What I said applies to all logic, CMOS and non-CMOS technology.
    Have you noticed that as PCs run at faster clock speeds the heat sinks on the CPU are getting bigger. The PCs generate more heat and the fans have to work harder to keep the mother board cool.
  10. crutschow
    Mar 14, 2008
    13,502
    3,376
    7400 TTL logic uses bipolar transistors, takes a lot of static power and that power only goes up slightly with frequency.
    74#C#00 and CD4000 series logic are CMOS and take very little static power but the power goes up with frequency since most of the power goes into charging/discharging circuit capacitances and that power is a linear function of frequency.
