Admittance Magnitude in a Parallel RC Circuit
Ryzing
Joined Sep 22, 2010
I some have problems regarding the parallel RC circuit and it is the admittance magnitude. I have tried to apply the solution that was given to me in the text book. Here is my attempt on the question:
"R=14 Ohms, C=260µF & e is a 990 V, 250Hz power supply. Calculate the magnitude of the admittance of the circuit?"
The solution:
1/6.28x260x 250=2449
990/2449=40424
990/14=70.714
40424^2+70.714^2 square root=339
I need someone to correct me on this. Thanks.
t_n_k
Joined Mar 6, 2009
5,455
Admittance [Y] is simply .....
Y=1/R+jωC
So magnitude, |Y|=sqrt((1/R)^2+(ωC)^2)
The Electrician
Joined Oct 9, 2007
2,970
The solution:
Your arithmetic here is wrong. The result is not 2449, but rather 2.449E-6. And besides that you haven't done the arithmetic right, you have used a value of 260 farads for the capacitor rather than the correct value of 260 microfarads.
990/2449=40424
990/14=70.714
You don't need to involve the value of the applied voltage, 990 volts, because the admittance has nothing to do with the applied voltage.
