ADM1270 - High voltage input protection device as current limiter
34,420
Suggest you read pages 15, 16, and 17 of the data sheet to learn how to connect it as a current limiter.
If you have any questions after that, get back with us and we'll try to answer them.
34,420
i roughly know how to connect as a current limiter but how to compute the value for Rsense?
Did you read the section titled "SETTING THE CURRENT LIMIT (ISET)" on page 16?
For example, if you use the default current sense voltage limit (Vlim) of 50mV, then you would need a Rsense of 50mV / 9A = 5.55mΩ.
You can vary Vlim from 12.5 mV to 62.5 mV to adjust the limit current and compensate for the particular Rsense resistor value you may have.
Skubby SkinnyChubby
Joined Jun 19, 2015
25
yeah i did, but still kinda confuse. Thanks alot, I will read the user guide again
#12
Joined Nov 30, 2010
18,224
What is this 9A powering?
is used to powering a DC motor
What is the normal current?
as in...??
What is the normal current the motor uses? Why is this particular motor unable to limit its own current? Billions of motors run properly if only given the right amount of voltage. What makes this one different?
