adjusting offset
Discussion in 'The Projects Forum' started by hami1101, Feb 9, 2012.
  1. hami1101
    Sep 12, 2011
    6
    Hello Everybody
    I am using CA3140 as a comparator and I need pulses of 5 volt at its output. I am getting pulses at the output but they go in negative range as well and also the output is higher than 5 volts, if anybody can help me out that what kind of settings I have to made to get 5 volts output pulses. The datasheet of CA3140 can be seen through following link.
    http://www.intersil.com/data/fn/fn957.pdf
    Thanks everyone
  2. wayneh
    Sep 9, 2010
    12,368
    3,224
    Show the schematic of your current setup.
  3. hami1101
    Sep 12, 2011
    6
    @wayneh this is how I am connecting my circuit and giving a signal of 2 Volts at the non inverting input and connected a voltage divider circuit at Inverting input with 5 Volts and supply voltages are + and - 5Volts
      File size:
      10.6 KB
      17
