Adjustable Square wave generator
Discussion in 'The Projects Forum' started by zohonie, Jan 20, 2011.
  1. zohonie
    Dec 2, 2010
    10
    I would like to find the easiest way to create an adjustable square wave. The wave needs to be centered at 2.5 V. The magnitude of the wave must be adjustable between 0 and 5 v by a potentiometer. The frequnecy also adjustable between 0-4Hz also by a pot. I'm very new to electronics so please be specific in your explaination. It would be best of there is a commerical board that can do this. Thank you.
  2. Wendy
    Mar 24, 2008
    20,772
    2,540
    A simple 555 circuit with an output pot and cap will do this. What kind of load are you driving? No time now, but I'll be glad to throw a quick schematic up in a couple of hours.
  3. Wendy
    Mar 24, 2008
    20,772
    2,540
    OK, there is no specific board that will do then that I know of, but there are many things I don't know.
    Start with this...
    555 Hysteretic Oscillator
    And add this to the output...
    An even better square wave can be made by using this schematic...
    Make R1 very small compared to R2 (say 1KΩ/100KΩ)
    eric3404 likes this.
  4. tom66
    May 9, 2009
    2,613
    214
    If you want a 50% duty cycle I'd recommend either adding a flip-flop to the output of the 555 or using an op-amp oscillator.
  5. Wendy
    Mar 24, 2008
    20,772
    2,540
    No need, the latter schematic will achieve better than 50.1% with the ratios described. Ever done the math?
    A hysteretic oscillator using a CMOS 555 will also be very square.
  6. thatoneguy
    Feb 19, 2009
    6,357
    718
    When you say "level from 0-5V", do you mean swings from -2.5 to +7.5v, or swings from 2.5V (0V) to 0-5V? In other words, is the 0-5V peak to peak, or change from the 2.5v bias?
