Hello Everyone,
I have been working on rectifier deisgning. I have 20 Volts DC output from full wave rectifier. Now I want to regulate DC output to around 20 Vdc.
I need 20 V across my 200 Ω Load. So basically I need around 0.100 Amp current from voltage regulator.
Here is the schematic of Voltage Regulator IC (Please find the attachements & refer page no. 1 & 10 of application note)
Can I use this voltage regulator only with Output Current sensing/ Limiting Resistor Rcso?
( I do not need voltage divider using R1,R2 as I already have load with 200 Ohms)
It would be nice to hear suggestions from you.
Regards,
Regards,
