Adjustable low pass filter
Discussion in 'The Projects Forum' started by saurabhkarnik, Aug 15, 2008.
  1. saurabhkarnik
    Jun 22, 2008
    22
    hey guys... could u please tell me if it is possible to design an adjustable LPF between 100hz-1Mhz by using varicap or something.... what i'm talking is it possible or completely hypothetical... if not possible in what frequency ranges should i use different adjustable filters
  2. Audioguru
    Dec 20, 2007
    9,411
    896
    A varicap is used at 100MHz, certainly not at 100Hz.
    You might be able to find a varicap used for an old AM radio that tunes down to 540kHz.
    20 or 30 years ago a "transconductance amplifier IC" was used as the variable resistor in a lowpass filter. CA3080, LM13600 and LM13700 rings my bell.
  3. Wendy
    Mar 24, 2008
    20,772
    2,540
    100Hz to 1 Mhz, the range is a bit wide. It might be possible to make an active filter, but not very likely. 100Hz to 10Khz is a lot closer I would think.
    In the case of an active filter the variable component would be a resistor or two (you can gang resistors on one shaft).
  4. saurabhkarnik
    Jun 22, 2008
    22
    how about this
    if i make a rc filter cutoff will be given by 1/rc..
    so if i use a pot or a varicap and use stepper motor to vary it by microcontroller is it possible...
  5. bertus
    Administrator
    Apr 5, 2008
    15,796
    2,384
    It seems to be possible. Take a look at this commercial product (PDF).
    Greetings,
    Bertus
