Adjustable delay switching of two relays alternately
Discussion in 'General Electronics Chat' started by adjeiwaf, Mar 4, 2015.
  1. adjeiwaf
    Mar 4, 2015
    I need to alternately switch two dry contacts /relays with variable time delays say 15mins or 20mins intervals .Think a 555 timer would work but will it be adjustable and have these two outputs?
  2. #12
    Nov 30, 2010
    16,705
    7,358
    One timer chip can not count both 15 minutes and 20 minutes at the same time. It will be adjustable if you build it to be adjustable. A 555 timer is really stretching to do 20 minutes. Better try a CD4020 counter chip.
  3. adjeiwaf
    Mar 4, 2015
    kindly help e with cd 4020typicadiagram l
  4. MikeML
    Oct 2, 2009
    5,451
    1,066
    Start by downloading and reading the 4020 data sheet. It will likely have all you need to proceed.
  5. Reloadron
    Jan 15, 2015
    1,055
    275
    You can as mentioned build your own circuit around a CD4020 timer chip and a Google of CD4020 Timer Circuits will yield dozens of circuits or as Mike mentioned, work from the data sheet. If this is for a commercial or industrial application another option is to simply buy a timer relay and a Google of Timer Relays will also bring up dozens of solutions which are plug and play. Since I have no clue as to your location I can't suggest manufacturers or model numbers of plug and play solutions.
    Ron
  6. #12
    Nov 30, 2010
    16,705
    7,358
    I was designing circuits before the Internet was invented. I had to read the datasheet and teach myself how to connect chips. I assumed everybody did that. AmIright?
  7. mcgyvr
    Oct 15, 2009
    4,795
    979
    No just old :p
    Sadly.. The datasheet is usually the last thing people look at now a days..
    Way too many forums/tutorials/youtube videos/blog posts,etc.. about EVERYTHING...
    #12 likes this.
  8. #12
    Nov 30, 2010
    16,705
    7,358
    Let me clarify: Before the internet was invented, did everybody have to read the datasheet and teach themselves how to connect IC's?
    Reloadron likes this.
  9. Reloadron
    Jan 15, 2015
    1,055
    275
    Before the Internet was invented I had to find the data sheet. If the data sheet wasn't in the department library then I took a walk to the main company library. The real bitch was before the copy machine was available.
    Ron
  10. #12
    Nov 30, 2010
    16,705
    7,358
    OMG! I couldn't live like that!
    I have to go back to the datasheet a dozen times during a design.
  11. mcgyvr
    Oct 15, 2009
    4,795
    979
  12. Reloadron
    Jan 15, 2015
    1,055
    275
  13. djsfantasi
    Apr 11, 2010
    2,915
    881
    Before the Internet, I got the Texas Instruments TTL Data Book... And The CMOS Cookbook...
