Homemade Adjustable Dc Voltage Regulator by circuit, and you will learn about Dc Voltage Regulator and circuit by practical design and we will use lm350k.
About adjustable dc voltage regulator design
You will be able to edit output voltage by Variable resistance in the circuit, and the range of DC voltage regulator is 1.2 volt to 24 volt.
The voltage regulator need voltage source 220v to work, and in this circuit we will use lm 350 k, the current of lm 350 k is 3A.
LM 350k datasheet
https://drive.google.com/file/d/0B3Zn-qbi_n-LeEMxNEdfdERtWTQ/preview
Adjustable Dc Voltage Regulator circuit
Circuit Components
Voltage Regulator: LM 350k.
VR: 10 k Ohm.
Resistor: 220 Ohm-10 Ohm 2w.
Capacitor: 4700 uf 50v - 0.1 uf 50v - 100 uf 50v - 47uf 50 v.
Diode: 7*1N4007.
Led: 1 red.
24V 3A electrical transformer.
electric fuss
Homemade dc voltage regulator Video
