address decoding in 8085
Discussion in 'Homework Help' started by hsbahri, Nov 17, 2011.
  1. hsbahri
    Nov 17, 2011
    Please help me solve this question.
    An 8085 system has 3 memory chips labelled ic1, ic2 and ic3 with 8 kbytes,4kbytes and 4 kbytes each resp.Design a circuit such that ic1 has memory addres 0,1,4,5,8,9 etc.IC2 has address 2,6,a,e etc and ic3 has addresses 3,7,b,f etc
  2. MrChips
    Oct 2, 2009
    12,624
    3,451
    This looks like homework question to me.
  3. t06afre
    May 11, 2009
    5,939
    1,222
    Your question do not make much sense either to me at least. In a 8085 system. You will most often use the higher part of the address bus for decoding. I also do not see any logic in the "adores 0,1,4,5,8,9 etc" statement. Homework or not. I think you need to rephrase your question in order to get any help
  4. RiJoRI
    Aug 15, 2007
    536
    26
    It's screwy, but I think using A0..A2 for chip selects will do the trick? But the decoding for the upper 4K of IC1 will need more tricks...
    --Rich
    Only a teacher could think of that!!
