additions for lcd code
Discussion in 'Embedded Systems and Microcontrollers' started by foxbrain, Jul 6, 2011.
  1. foxbrain
    Jun 27, 2011
    i have this code that is used to program lcd 16X2 using atmega16A:
    Code ( (Unknown Language)):
    1.
    2.
    3.
    4.
    5. /*----------------------------------------------------------------
    6. -----------------HEADER FILES-------------------------------------
    7. -----------------------------------------------------------------*/
    8. #include<avr/io.h>
    9. #include <util/delay.h>
    10.
    11.
    12. #define SETBIT(ADDRESS,BIT) (ADDRESS |= (1<<BIT))
    13. #define CLEARBIT(ADDRESS,BIT) (ADDRESS &= ~(1<<BIT))
    14. #define CHECKBIT(ADDRESS,BIT) (ADDRESS & (1<<BIT))
    15.
    16. /*----------------------------------------------------------------
    17. -------------CONNECTION BETWEEN LCD AND ATMEGA32-----------------
    18. -----------------------------------------------------------------*/
    19. #define DATA_DDR    DDRB
    20. #define DATA_PORT     PORTB
    21.
    22.
    23. #define CONTROL_DDR        DDRA
    24. #define CONTROL_PORT     PORTA
    25. #define Enable_Pin        2
    26. #define RegSelect_Pin     0
    27. #define ReadWrite_Pin     1
    28. #define CONTROL_MASK     0X07
    29.
    30.
    31. /*----------------------------------------------------------------
    32. -------------CONTROL BITS OF LCD --------------------------------
    33. -----------------------------------------------------------------*/
    34.
    35. #define Set_Enable              CONTROL_PORT|=_BV(Enable_Pin)
    36. #define Clear_Enable             CONTROL_PORT&=~_BV(Enable_Pin)
    37. #define Write_Lcd                CONTROL_PORT&=~_BV(ReadWrite_Pin)
    38. #define Read_Lcd                  CONTROL_PORT|=_BV(ReadWrite_Pin)
    39. #define Select_InstructionRegister    CONTROL_PORT&=~_BV(RegSelect_Pin)
    40. #define Select_DataRegister          CONTROL_PORT|=_BV(RegSelect_Pin)
    41. #define Data_Lcd(a)               DATA_PORT=a
    42. #define delay(a)               _delay_ms(a)
    43.
    44.
    45.
    46.
    47. /*----------------------------------------------------------------
    48. -----------------SEND A CHARACTER TO LCD-------------------------
    49. -----------------------------------------------------------------*/
    50. void Lcd_Send(unsigned char a)
    51. {
    52. Select_DataRegister;
    53. Write_Lcd;
    54. Data_Lcd(a);
    55. Set_Enable;
    56. delay(30);
    57. Clear_Enable;
    58. delay(30);
    59. }
    60.
    61.
    62.
    63.
    64.
    65.
    66. /*----------------------------------------------------------------
    67. -----------------FUNCTIONS TO INITIALIZE PORTS--------------------
    68. -----------------------------------------------------------------*/
    69. void Init_Ports(void)
    70. {
    71. DATA_DDR=0XFF; //Setting data port for output
    72. CONTROL_DDR=CONTROL_MASK;//setting selected pins of control port for output
    73. CONTROL_PORT&=~(_BV(Enable_Pin)|_BV(RegSelect_Pin )|_BV(ReadWrite_Pin)); //setting values to 0 at starting
    74. }
    75.
    76.
    77.
    78.
    79. /*----------------------------------------------------------------
    80. ------------FUNCTION TO INITIATE LCD -----------------------------
    81. -----------------------------------------------------------------*/
    82. void Init_Lcd(void)
    83. {
    84. char init[10];
    85.  int i;
    86.  init[0] = 0x01;
    87.  init[1] = 0x38;
    88.  init[2] = 0x0c;
    89.  init[3] = 0x06;
    90.  init[4] = 0x80;
    91.
    92. Select_InstructionRegister;
    93. Write_Lcd;
    94.    for(i=0;i<5;i++)
    95.    {
    96.    Data_Lcd(init[i]);
    97.    Set_Enable;
    98.    delay(30);
    99.    Clear_Enable;
    100.    delay(30);
    101.    }
    102. }
    103.
    104. ///////////////////
    105. void gotos(char x,char y)
    106. {
    107.    char val;
    108.    switch (y)
    109.    {
    110.    case 0:
    111.       val=0x80+0x00+x;
    112.       break;
    113.    case 1:
    114.       val=0x80+0x40+x;
    115.       break;
    116.    default:break;
    117.    }
    118.    Select_InstructionRegister;
    119.    Write_Lcd;
    120.     delay(30);
    121.    Data_Lcd(val);
    122.    Set_Enable;
    123.    delay(30);
    124.    Clear_Enable;
    125.    delay(30);
    126. }
    127.
    128.
    129. /*----------------------------------------------------------------
    130. ----------------MAIN FUNCTION--------------------------------------
    131. -----------------------------------------------------------------*/
    132. int main(void)
    133. {
    134. int len,i;
    135. char string[] = {'H','E','L','L','O',' ','J','O','J','O'};
    136. Init_Ports();
    137. Init_Lcd();
    138. len=10;
    139. gotos(0x04,1);
    140.    for (i=0; i< len;i++)
    141.      Lcd_Send(string[i]);
    142.
    143. }
    144.
    145.   [/i][/i]
    what additions can i add on it?
    like: to check if the lcd is busy or not , clear only the first line...
    thanks
