I have an IR repeater that has a remote sensor plugged into it (3 conductor 1/8" plug) to receive the IR signal from my remote. It then has IR led emitters that are placed in front of each peice of equipment to be controlled. I would like to be able to control my stereo from a second location. I tried to use a stereo Y splitter to connect 2 sensors into the single jack on the back of the repeater, however when both sensors are plugged in, neither works. If I unplug one, the other works fine and visa versa. Any ideas how I can get both to work? I'm on a very limited budget, so buying another unit or other expensive equipment is not an option.
