Hi guys, im new to this please be kind lol.
I have a Low gear Mud mixing drill that is powering a scissor lift
My issue is i need the scissor lift to stop at max and minimum. I was going to attach 2 momentary to the front and back, not to stop the motor but to disconnect the power going to the brushes/winding.
But when i disconnect the LEFT switch and add a N/C momentary it all works, but it shuts down BOTH left and right.
If i disconnect 1 of any wires nothing works
I have 2 wires on LEFT setting. 1 to brushes 1 to winding
2 wires for RIGHT setting ( same as above )
AC lines that run into the trigger and 2 black lines that run from trigger to drill, not sure where.
The trigger also has 3 speed settings with pressure.
im so lost please help.
