Hey Guys, long time member, first post but still a newbie. Here's the info then the question. My Lucent 8410 work phone has an 45 ohm speaker inside which is not very loud on high volume (speaker mode). I want to use an amplified external speaker set for greater volume. My plan is to install a 3.5mm female jack on the back of the phone and use an amplified 8 ohm computer speaker set. My question is .... since the 8 ohm computer speaker set is amplified, will the mismatched impedance 45/8 damage the phone amp. My thought is that since the external amp will be driving the speakers, the phone amplifier won't be over driven? Am I on track or way off base? Thanks :O)
