Adding Apparent Load
Discussion in 'Homework Help' started by DYLH, Nov 25, 2013.
  1. DYLH
    Aug 13, 2013
    28
    Appologies, this isn't actually a homework problem, but I thought that this may be the best place to get academic input.
    Which is the correct way to solve this?
    Find the total VA and PF for a circuit with the two loads:
    Apparent Load 1 = 250 VA w/ 0.75 PF
    Apparent Load 2 = 150 VA w/ 0.90 PF
    Method 1
    Real Power 1 = 0.75 * 250 = 187.5 W
    Real Power 2 = 0.90 * 150 = 135 W
    Total Apparent Load = 250 VA + 150 VA = 400 VA
    Total Real Power = 187.5 + 135 = 322.5 W
    Resulting Power Factor = 322.5 / 400 = 0.80625
    Method 2
    Reactive Power 1 = sqrt(250^2 – 187.5^2) = 165.36 VAR
    Reactive Power 2 = sqrt(150^2 – 135^2) = 65.38 VAR
    Total Reactive Power = 230.7 VAR
    Total Apparent Power = sqrt(322.5^2 + 230.74^2) = 396.55 VA
    Resulting Power Factor = 322.5 / 396.55 = 0.813
  2. t_n_k
    Mar 6, 2009
    5,448
    783
    Method 2 is correct.
  3. DYLH
    Aug 13, 2013
    28
  4. WBahn
    Mar 31, 2012
    18,087
    4,917
    How about just doing the math from the definitions.
    Do you know about complex power? If so, things are very easy. If not, then things are a bit harder, but not too much.
  5. WBahn
    Mar 31, 2012
    18,087
    4,917
    You are neglecting to take into account whether the power factor is leading or lagging. If both are leading or both are lagging, then you will get the results in Method 2. But if one is leading and the other is lagging, which is precisely the case when you are doing power factor correction, then you have to take that into account.
    DYLH likes this.
  6. DYLH
    Aug 13, 2013
    28
    Good Point.. Thanks!
