adding antenna to clock radio
Discussion in 'General Electronics Chat' started by lokeycmos, Jul 29, 2011.
  1. lokeycmos
    Thread Starter Active Member
    Apr 3, 2009
    432
    7
    i need to solder on an external FM antenna to my clock radio. i attached some pics. there is a ferrite rod for am. but i cant see anything for fm. could someone please point out where i would solder the antenna to the board? TY
      File size:
      307.5 KB
      104
      File size:
      310.8 KB
      136
      File size:
      294.8 KB
      96
  2. lokeycmos
    Apr 3, 2009
    432
    7
    a few more pics
      File size:
      295.4 KB
      79
      File size:
      292.8 KB
      84
      File size:
      294.6 KB
      70
  3. Audioguru
    Dec 20, 2007
    9,411
    896
    The FM antenna is usually a short piece of wire from the circuit that is wrapped around the AC cord for a few turns.
  4. lokeycmos
    Apr 3, 2009
    432
    7
    checked that already...nada
  5. mcgyvr
    Oct 15, 2009
    4,787
    973
    Looks to me that its the trace at the top of the board of picture 2. The one connected to the pad labeled "FM"
  6. Audioguru
    Dec 20, 2007
    9,411
    896
    The short trace on the pcb is too short for an antenna for the FM broadcast band. It should be near 80cm long like a long whip or like the power cord.
  7. lokeycmos
    Apr 3, 2009
    432
    7
    does anyone know of a good site for schematics? it a GE 7-4813B. i did figure out that the FM antenna is coupled to the power cord. instead of the power transformer having 2 primary and 2 secondary leads, it has 6 secondary leads. some how the antenna is coupled to it throught the swirl traces. hoping i can find a schem. ty
  8. Wendy
    Mar 24, 2008
    20,772
    2,540
    You could try a 5' piece of wire with 1' run parallel to the power cord to see if it helps. You don't always need to connect an antenna directly to a circuit.
    If it works, but is still too weak, try 8', as that approaches the resonant length of 88Mhz.
  9. Audioguru
    Dec 20, 2007
    9,411
    896
    The very cheap radio will be overloaded by strong local stations if its antenna is too good. Then the stongest stations will be all across the dial like my cheap Sony Walkman FM stereo radio (it has a local-distant switch that attenuates the antenna in the local position).
    The datasheet for Toshiba's TA2003 radio IC has recommended simple schematics of radios that use it.
  10. trader007
    Feb 27, 2010
    222
    19
    This is a bit of a thread bump, but my question directly relates to this topic.
    If you have a cheap radio (mine is a armband radio), and it uses the headphone cord as the antenna (like cellphones do), is there a way to add an external antenna?
    I have a reason for putting a tiny fm tuner in a custom boombox... but I dont know where I should hook up an external antenna.
  11. Dodgydave
    Jun 22, 2012
    5,142
    768
    Pin 1 is the fm signal input, try following the track from there.
