Ok I have fished the new telephone wire from the phone network interface box to the new phone outlet in my living room. The outlet is correctly rigged up, all I need to do now is connect the other end of the telephone wire to the customer side panel of the phone network interface gray box in my cellar.
I just have a few last minute questions.
First when I look in the customers side panel I see 3 blocks each block has 4 screw terminals ( yellow , green , black , red ) and a phone jack.
I am using all the blocks already. But their are like 4 or more spaces to add additional blocks. My problem is where do I get these blocks and how do I install them.
Hopefully I don't need the phone company to open up their side panel to install them?
Since this new phone outlet is just to add an additional phone not to add another seperate line (i.e it is going to be on the same phone number )
Can I instead of getting a new block installed just screw the wires to a used green and red terminal. Or can you not put 2 greens on the same terminal.
Thanks for any help
Thanks for any help
