Hi all, was hoping someone could explain how a power supply with +-12v and 5v output could be combined to create multiple voltages.
I have included the wiring diagram of both circuits. By combining +12v and 0v of 5v circuit a 29v supply is available across the 5v and -12v, how does this circuit work? As I see it link between +12v and 0v will cause caps to charge, can't see how voltages add together especially with regulator in circuit. Also if 5v and +12v are combined a 7v supply is available across both 0v terminals, this is as described in book that I got wiring diagram from, but again can't see how it works
Appreciate if anyone could explain how voltages and currents work in these circuits, also if there is any other voltages available.
