As technology advances, auto manufacturers have replaced dash gauges with "idiot lights". The problem with lights is that they come on once the failure happens (usually).
I have a 2012 Jeep with such lights and would like to add a voltage gauge. It should read voltages as follows:
1. When the key is in the accessory position, provide a voltage reading on the battery.
2. When starting the vehicle, provide a voltage reading to display the draw on the battery.
3. When running, provide a voltage reading on the alternator(charging).
I believe the first two readings can be taken across the battery posts. The third (charging) would require the use of a relay, wouldn't it?
Lyman
Lyman
