Adding a simple Peak led and Vu meter
Discussion in 'The Projects Forum' started by Precious Molina, Sep 11, 2015.
  1. Precious Molina
    Sep 6, 2015
    23
    if i tap a peak lead and vu meter to my main output(soundcard)
    Will my audio degrade?
    or should i put something
  2. blocco a spirale
    Jun 18, 2008
    1,461
    370
    The Peak LED circuit may have a detrimental effect (non-linear diode and cap to 0V) so take its input from the the output of OP2 to avoid loading the output to the soundcard.
    Precious Molina likes this.
  3. ScottWang
    Aug 23, 2012
    4,933
    777
    You can using the comparator as LM393 to setup the voltage to do the voltage comparator that you want to detect, and you can also using ne555 to do the monostable circuit to keeping the peak state with led to show the state how long you like, or you want to have a led fade out effect.
    cmartinez likes this.
  4. cmartinez
    Jan 17, 2007
    3,698
    2,792
    I agree with Scott, a comparator is the way to go, since it usually has a high impedance input.
