I've got a small aerator running for a fish pond but its only solar powered and now its coming into winter I'm thinking of adding a battery to it so it can run for longer (also means during the summer it should hopefully run over night)
The specs on the pump are:
Peak-power: 2.5W, Max-power voltage: 7.68V, Max-power current: 325mA
Is something as simple as the circuit below enough for it or do I need anything else, the issue I can see is that both the solar panel and battery will provide current during the day so that may be a problem?
