adding a flashing colon to my clock
Discussion in 'The Projects Forum' started by magnet18, Jun 5, 2011.
  1. magnet18
    Thread Starter Senior Member
    Dec 22, 2010
    1,232
    125
    OK guys, the clock is coming together, and I finally got the time setting figured out (had to make some changes), so now it's time to figure out how to add some features.
    I was thinking that with some quad and gates I can make an alarm pretty easily, but I was wondering how to do a blinking colon, like the one shown in this video-
    http://www.youtube.com/watch?v=4bl5kSr8C3Q
    I already have the tubes (and like 50 of them :p), they're IN-24, datasheet here- http://tubehobby.com/datasheets/in24.pdf, scroll down for translation of the important stuff.
    So basically what I need to do is reverse the voltage twice a second to get the blinking (theres 2 little metal plates in there, the cathode glows and the anode doesn't, it's designed to be reversed).
    I already have the 2 Hz signal from the 4060, but after that everything I've drawn up in my head has hit brick walls.
    Ideas?
  2. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
  3. magnet18
    Dec 22, 2010
    1,232
    125
    I have some NE-2's, but they don't look the same for the colon with the half glowing, half not glowing.
    And I don't mind the color. :)
    And I have 60 of these. :p
  4. magnet18
    Dec 22, 2010
    1,232
    125
    Well, I was thinking that a 4013 could be used with the NPN MPS-A42 and it's PNP equivalent, thoughts?
  5. Bernard
    Aug 7, 2008
    4,233
    414
    Your idea should work, connect 4013 as toggle FF. Might need to adjust 20K to give desired brightness. With 300V rating, might not need V divider.
  6. magnet18
    Dec 22, 2010
    1,232
    125
    That would work, but theres only 2 contacts on the tube.
    Anode, and cathode.
    I have an idea I worked on a bit during school, I'll draw it up in a bit and see what you think...
  7. magnet18
    Dec 22, 2010
    1,232
    125
    This is the first thing that comes to my mind, but I need to switch the high side...
  8. magnet18
    Dec 22, 2010
    1,232
    125
    [​IMG] still gets tied to D, right?
  9. Bernard
    Aug 7, 2008
    4,233
    414
    For FF, yes NotQ to D. Here is another attempt, assuming that you have MPS-A92, PNP hi-V. 0r other sim.
  10. magnet18
    Dec 22, 2010
    1,232
    125
    Thanks, I'll give it a try.
    I need to order some transistors though :(
  11. Ron H
    Apr 14, 2005
    7,050
    657
    How does this flash? It seems to me like the dots will toggle back and forth.
  12. Bernard
    Aug 7, 2008
    4,233
    414
    I was short of time before, think it can be simplified a bit:
  13. Ron H
    Apr 14, 2005
    7,050
    657
    Same question: How does that make a flashing colon? It looks to me like it makes the two dots flash alternately.
    EDIT: I found a picture of the IN-24. Magnet, how can you make a colon out of this?
    This is a colon:
    Apparently, you are just trying to make the two plates flash alternately, but you sure led me down the garden path by calling that a colon.:mad:
  14. magnet18
    Dec 22, 2010
    1,232
    125
    When you flash the plates alternately it looks like a colon to me.
    I linked to the video in the first post showing the effect I wanted, I didn't know that it wasn't still considered a colon.
    Is there a specific name for that thing between the numbers on a clock?
  15. #12
    Nov 30, 2010
    16,665
    7,310
    If you flash them quickly, persistence of vision will make them look like a colon, but it will look like it's always "on".
    I don't know what single word would describe 2 dots, one above the other, alternating, but I do hope you get this working soon. Every time I read your title my mind goes to "intestinal problems". I surely wouldn't want my colon to flash!
  16. Ron H
    Apr 14, 2005
    7,050
    657
    Sorry I missed the video. I guess I have a mental block or something.
    That is definitely not a colon, but it is definitely some alternately flashing lights.:D
    I personally think the classic flashing colon would look better. I would probably get 4 of these neon dots (not sure which model). I like the INS-1, but it might be too small.
  17. magnet18
    Dec 22, 2010
    1,232
    125
    I actually just ordered ten more IN-2's for $2.50, I'm considering using those...
    I'll build both and see which I like better.
    I like the INS-1's also, but they're definitely much too tiny (5mm!)
    I'll consider them if I ever make a smaller clock.
  18. Wendy
    Mar 24, 2008
    20,772
    2,540
    A simple neon connected to 120VAC through a 1MΩ resistor will light up both leads. High voltage DC will light up one lead (which is a point).
  19. Bernard
    Aug 7, 2008
    4,233
    414
    How about an optical coupled triac driver, 22k & 120VAC. Use 1 sec. ,50% duty cycle to drive coupler, & you have blinking colon. [ If 120 V AC is high enough to strike ]
  20. SgtWookie
    Jul 17, 2007
    22,183
    1,728
    It needs 160v to strike.
