adding a capacitor to a switch mode PS's output
Discussion in 'The Projects Forum' started by stirling, Dec 11, 2011.
  1. stirling
    Mar 11, 2010
    52
    Hi - Here's a quote from a leading manufacturer of stepper motor (chopper) drives.
    I always use unregulated supplies for driving steppers and have never had a problem but I know others choose to use switching supplies.
    I recently advised someone who was using a switching supply and who was experiencing much lower than expected (low speed) torque that they might consider following the above advice to see if it improved things.
    The response was to the effect of "never add a capacitor to the output of a switching supply - it will seriously screw with the supply's internal electronics".
    So now I'm confused. Tried searching for advice/examples/papers on supply design etc. but to no avail for this particular question. Can anyone shed any light on the pros and cons please?
  2. praondevou
    Jul 9, 2011
    2,936
    489
    I'm not sure about the torque issue.
    The output capacitor of a SMPS, however, is part of the feedback loop and needs to be taken into consideration.
    I would not say, NEVER add a capacitor to an SMPS output. Even with different values it can still work.
    The SMPS may start to oscillate at different load levels/input voltages, though.
  3. jimkeith
    Oct 26, 2011
    539
    99
    Another issue here is "fold-back current limiting" that some power supplies have--this could be causing the power supply to trip as it attempts to charge the capacitor on power-up.
  4. stirling
    Mar 11, 2010
    52
    Thanks both for your replies. I should make clear the system in question does NOT currently have a capacitor. It was when I suggested adding one that the issue came up.
