I have a "concealed" LED in my car for the radar detector and I recently added a second LED using a splitter supplied by the manufacturer. Now both LED's are too dim. I was thinking of using a relay and powering the relay coil off the LED power wire (and then using the relay output to power the LED's. However, that's just not going to work because the 2.4vDC and extremely low amperage that powers the LED is just not enough to trigger a mechical relay.
The guys at the local electronics shop (Baynesvilled Electronics) suggested I post this question here.
Is there any way for an ordinary schmoe to make these two LED's as bright as they should be?
