Switch mounted on the board is ideal. The LEDs should be there as well. I have the box ready to use. next week I can call some board makers, I don't know what they will ask, drawing or whatever...You can locate the UHF receiver a fair distance away from this control board. The control board should be in a box that is close to the existing switch box. You should connect the two boxes with conduit.
You will need to run 5 wires through the conduit to the original switch box:
BLU - goes to the white/close switch and motor.
RED - common to all three switches; also connects to BRN going back to the motor.
BLK - goes to the black/open switch and motor.
MRN - maroon; comes from the motor.
MRN2 - goes to the red/stop switch. This could be a maroon wire with short pieces of black or colored shrink tubing wrapped around it periodically to differentiate it from the plain maroon wire.
Still need the enable/disable switch, and whether it will mount on the board or separately.
Still need to decide on the terminal blocks for HV and LV
Still need to decide on the LEDs to show that 12v power is on, and the fuse is good - unless you really don't want those options. If you do want LEDs, then on-board ENA/DIS switch would make the most sense.
Need to decide on the box to enclose it in. The box should be about 4" square on the inside to give room for the board and the wires. You don't want it to be a squeeze fit.
I just noticed I put a wrong caption on the STOP terminal - it needs to be NC, not NO. If STOP were connected to a NO terminal, you would have to press STOP and CLOSE or OPEN at the same time.Does the NC switch allow current to flow during the whole period the door is being closed? I think from memory 200mA
How would you like it?I need to double-check that, but I need more coffee first.
Yesterday I tried the previous version "not the latest one" as a prototype and all is working as expected. the door opens closes stops and the switch adds the remote or eliminates it.Did some more thinking about it, and finally realized that you could get by using two fewer of the PR39MF51 TRIAC switches. The STOP button on the remotes will still work, but not the UP nor DOWN buttons.
That is exactly how I want it to function. except the remote single is not strong. I have to come too close to the unit for it to catch the signal.
Could not have done it with out you.I am glad that you got it to work.
Yes.Does your statement mean that you are not interested in the latest version that uses fewer parts, and leaves the remote STOP button functional, but disconnects the UP/DOWN buttons?
Open.Is the receiver either open to air (exposed) or enclosed in a plastic box?
a wall or 2 between but not more than that.I thought that unit was supposed to receive up to 40 meters away? That would be ~43 yards, or 131 feet. That would be direct line of sight though - if you are in a reinforced concrete or steel building, the distance would change considerably, and not in your favor.
I was right when I thought you will never run out of ideas.You might be able to increase the range in a single direction by using a corner reflector.
I could not find 1/4 watt at element141) The actual part numbers for the resistors
no clue here.2) The actual board stand-offs
will call around.3) PCB manufacturer
Ah, I see.The area in the center of the board is @ 450VAC. I don't want any extra copper in there. The large terminals connect the power from the motor. The small terminals are at 12v DC. That is why there is such a difference in the size of the terminals. The small terminals would have pins too close together.
Qty Value Device Parts
1 470 .5W R-US_0309/12 R4
http://au.element14.com/vishay-bc-components/sfr16s0004700ja500/resistor-0-5w-5-470r/dp/9476059
VISHAY BC COMPONENTS - SFR16S0004700JA500 - RESISTOR, 0.5W 5% 470R
4 560 .5W R-US_0309/12 R1, R2, R3, R5
http://au.element14.com/welwyn/mfr4-560rfi/resistor-metal-film-560ohm-500mw/dp/1833360
Welwyn MFR4-560RFI Metal Film 560 Ohm 500mW 1%
6 M2.5x15mm SPACERS
http://au.element14.com/ettinger/05-02-153/spacer-m2-5x15-ni/dp/1466780
ETTINGER - 05.02.153 - SPACER, M2.5X15-NI
$0.415/ea
Items you should know about already, and either have or will order this time.
5 1725656-2 X1, X2, X3, X4, X5
1 CTB77VP/2 CTB77VP/2 X6
1 CTB77VP/3 CTB77VP/3 X7
4 1.2K R-US_0207/10 R7, R8, R9, R10
1 CK7101 CK7101 S4
1 FUSE(800mA) FUSE F1
2 GRN LED3MM LED3, LED5
6 PR39MF51 PR39MF51N U1, U2, U3, U4, U5, U6
2 RED LED3MM LED2, LED4
by Jake Hertz
by Dale Wilson
by Aaron Carman
by Jake Hertz
