Add HOLD to voltmeter
Discussion in 'General Electronics Chat' started by Rogare, Mar 16, 2012.
  1. Rogare
    Mar 9, 2012
    78
    I've got a circuit that is essentially a voltmeter, and it receives very short pulses (on the order of microseconds) that need to be measured. I'd like to add a simple circuit between the input and the voltmeter that will hold the maximum input voltage for at least a few seconds. So, even if the input jumps to 10V for just a moment, the meter will display that value long enough to see. Is this as simple as an RC circuit?
    Thanks!
  2. MrChips
    Oct 2, 2009
    12,625
    3,451
    This is called a "sample and hold" circuit.
  3. crutschow
    Mar 14, 2008
    13,487
    3,371
    A sample and hold circuit requires a timing signal to perform the sample. You want a version of that called a peak hold circuit which doesn't require a separate timing signal.
    Rogare likes this.
  4. Rogare
    Mar 9, 2012
    78
  5. THE_RB
    Feb 11, 2008
    5,435
    1,305
    Many decent quality meters will have hold function and also min/max record functions.
    Prices are so cheap now you can get a meter with a ton of cool functions for $50 to $60.
  6. Ron H
    Apr 14, 2005
    7,050
    657
    Did you miss the part about the very short pulses?
  7. crutschow
    Mar 14, 2008
    13,487
    3,371
    Yes, the op amp design is slower, but more accurate. The diode peak detector will have an offset due to the diode forward voltage of 0.6-0.7V.
    The problem with the op amp design is the slow response time and slew rate of an op amp which will make it difficult to capture microsecond pulses.
    One better approach for a high speed peak detector is to use a fast S&H circuit modified to perform the peak detect function. Look at Application No. 9 in this ap note.
  8. THE_RB
    Feb 11, 2008
    5,435
    1,305
    Nope. My Fluke meters have "min/max recording" (which I mentioned above) and it's a very handy feature as it records the miniumum and maximum voltages, even if they are short pulses. I use it all the time for checking PSU rails, it will detect short term sags or overvoltage faults etc.
  9. Ron H
    Apr 14, 2005
    7,050
    657
    That's pretty cool. Maybe my Fluke has the same feature (duh).
    It must be an analog circuit, unless the Flukes (and others) have fast A/Ds.
    EDIT: I have a Fluke 89. It does have FAST MN MAX. Events can be as short as 1mS, with decreased accuracy (3.5 display digits). Our OP wants to capture events on the order of microseconds.
  10. THE_RB
    Feb 11, 2008
    5,435
    1,305
    Thanks for the info Ron, my Flukes are model 12 and I just went and had a look at the user manual.
    As you said in MIN/MAX record mode it won't accurately register the voltage of very fast transients as it is much too slow. The "capture" function for capturing open or short circuits is much faster but not of much use.
    It's beginning to look like a job for a 'scope or digital storage 'scope.
    Maybe a fast diode into a small cap would charge up the cap to something near the peak voltage of the transients? There will be the diode voltage drop and some leakage issues but it could be workable if he just needs a ball-park value and not a highly accurate value.
  11. Rogare
    Mar 9, 2012
    78
    That looks perfect, crutschow, thanks very much. Is there anything I should keep in mind when choosing an op-amp for the comparator?
  12. crutschow
    Mar 14, 2008
    13,487
    3,371
    The first thing to keep in mind is "don't use an op amp as a comparator". ;) The built-in compensation of standard op amps makes them too slow when used as a comparator for this application.
    You want a fast comparator IC such as one of these.
    Rogare likes this.
  13. Rogare
    Mar 9, 2012
    78
    Ha. OK, great. Thanks for the recommendations!
