Add DC offset
Discussion in 'The Projects Forum' started by raptorjp, Apr 17, 2009.
  1. raptorjp
    Nov 24, 2008
    11
    Hello!
    I have a DC motor drive that takes in 0-12VDC control. The drive only operates at 3-12VDC in practice. I have a control that outputs 0-10VDC. How would I add a constant 2-3VDC offset to my control output?
    I have tried making a simple voltage divider circuit with a potentiometer from a 24VDC power supply and placed that in series with the control output (0-10V) to try to get an input on the motor drive to 2-12V. Is this correct. When I did it I would only get 2-6V output to the drive.
    Any help would be great. Thanks.
    raptorjp
  2. bertus
    Administrator
    Apr 5, 2008
    15,803
    2,388
  3. raptorjp
    Nov 24, 2008
    11
    @Bertus
    Thanks for your reply. I just thought there was an easier way to add voltages without using op-amps. I mean what if I added 2 1.5V AA batteries in series with my 0-10V output?
    Thanks again.
    raptorjp
