Add Crystal Detector to Diode section of e-book
bertus
Joined Apr 5, 2008
22,276
That is a good suggestion.
I think the Ebook-developers will have a look at it.
There are still of those "glass" diodes available.
The AA119 is an example.
From a dutch supplier:
Rich (BB code):
N.B.
Wij hebben diverse Ma/com HF smd (schottky en pin) in kleine aantallen.
1N5711      =HP5082-2800, lange draden, milspecs                            1.75
1SS97       Medium barrier, verder als 1SS99, echter nog lagere C           4.90
AA119       =1N60 Germaniumdiode                                            0.45
BA182       zie BA482
BA281       50V Schakeldiode zeer lage capaciteit                           0.23
BA282       HF schak.; we hebben ook 482=483                                0.23
BA479S =379 PIN regel/schakeldiode axiaal 0.79
On this linkpage of the EDUCYPEDIA there are some schematics of crystal radio's:
http://www.educypedia.be/electronics/radiotuning.htm
Bertus
Wendy
Joined Mar 24, 2008
23,421
If one were written it would probably be in the Special Purpose diodes section. As I understand it a Schottky Diode is somewhat similar to a crystal detector.
Wendy
Joined Mar 24, 2008
23,421
Don't forget the venerable 1N34A
John
That is a conventional diode that is made from germanium instead of silicon. I'm not sure about diode detectors and shottky diodes, but I think they are the same basic types. If I can find definite confirmation I'll write up a paragraph.
Wendy
Joined Mar 24, 2008
23,421
Yep, but that doesn't mean it is the same thing. It just means they are drop in replacements.
From Wikipedia...
http://en.wikipedia.org/wiki/Schottky_diode
The Schottky diode (named after German physicist Walter H. Schottky; also known as hot carrier diode) is a semiconductor diode with a low forward voltage drop and a very fast switching action. The cat's-whisker detectors used in the early days of wireless can be considered as primitive Schottky diodes.
If you read up on cat's whisker diodes they used iron pyrite, not germanium.
Another proof.
https://secure.wikimedia.org/wikipedia/en/wiki/Cat's-whisker_detector
The wire touching the surface of the crystal formed a crude and unstable metalsemiconductor point-contact junction, forming a Schottky barrier diode. This junction conducts electric current in only one direction and resists current flowing in the other direction. In a crystal radio its function was to rectify the radio signal, converting it from alternating current to a pulsing direct current, to extract the audio signal (modulation) from the radio frequency carrier wave.
I'd be interested in how they used Gillette razor blades when our Dad's were kids. It was a common thing for crystal radios of that era.
Wendy
Joined Mar 24, 2008
23,421
Interesting. I thing some of the voltages are approximations, because I've seen lower voltages listed for Schottky diodes. For that matter I've seen a large variation on silicon, for low current applications I typically use 0.6V drop, but it goes up fast.
Another source...
http://www.teamnovak.com/tech_info/more_info/schottky.htm
A Schottky diode is a special type of diode with a very low forward-voltage drop. When current flows through a diode, it has some internal resistance to that current flow, which causes a small voltage drop across the diode terminals. A normal diode has between 0.7-1.7 volt drops, while a Schottky diode voltage drop is between approximately 0.15-0.45 – this lower voltage drop translates into higher system efficiency
Wendy
Joined Mar 24, 2008
23,421
OK, how about this tacked on to the Schottky Diode section.
There is an earlier version of the Schottky Diode, it was basically the first solid state RF diode rectifier, and that was the cat's-whisker detector or crystal detector. Basically a thin wire was moved across the surface of a crystal of raw semiconducting material until a location that acted like the diode was found. This was used during the earliest days of radio in crystal radios (hence the name) until more manufacturing friendly techniques and other devices were developed and discovered. Later hobbyist incarnations uses a Gillette razor, which had a silicon coating during the 1930 through 1950's.
To Dennis Crunkleton, please credit this to otto9K9otto if accepted.
jpanhalt
Joined Jan 18, 2008
11,087
That bizarrelabs is a great link. I had a cousin who was a POW. He didn't talk about it much.
Anyway, back OT: "Later hobbyist incarnations uses a Gillette razor, which had a silicon coating during the 1930 through 1950's."
That is apparently true, but I cannot confirm the dates it was used. According to the patent literature, some were coated with silicon, and some apparently had silicone. The link from beenthere suggests that almost any metallic oxide will work, e.g., the old double-edged, blued blades and rusty blades will work. Even copper that has been heated to form a copper oxide coating will work. You might consider adding another sentence to expand on the variations. Here is an unpolished suggestion for such a sentence:
"Other variations, some were used by POW's (add link), relied on metal oxides such as the surface of blued steel, rusty steel, or the copper oxide formed on a heated copper wire for the diode."
John
Wendy
Joined Mar 24, 2008
23,421
I'm not to sure of those dates either, think I ought to remove them?
I'm going to google around a bit to see if I can pin them down.
I like the addition.
OK, lets try it again. When we get it right I'll email Dennis for review.
There is an earlier version of the Schottky Diode, it was basically the first solid state RF diode rectifier, and that was the cat's-whisker detector or crystal detector. Basically a thin wire was moved across the surface of a crystal of raw semiconducting material until a location that acted like the diode was found. This was used during the earliest days of radio using crystals (hence the name) until more manufacturing friendly techniques and other devices were developed and discovered. Later hobbyist incarnations uses a razor, which is often referred to as a foxhole radio (so named because AM radios were banned in many places during WWII). Powered radios using local oscillators could be detected and traced (and were) during this era, crystal radios did not have this problem. Early razors had a silicon coating, but it is not critical as they are still being made by hobbyists today. Other variations, some were used by POW's from WWII on (http://bizarrelabs.com/foxhole.htm), relied on metal oxides such as the surface of blued steel, rusty steel, or the copper oxide formed on a heated copper wire for the diode. POW's were especially ingenious in creating components from the most unlikely of materials, and the diodes were absolutely critical to receive radio.
Wendy
Joined Mar 24, 2008
23,421
I spend a lot of time making experiments (usually several weeks), I spent maybe slightly over a day on this. I've got too many irons in the fire at the moment, and simple crystal radios are a constant and common as far as kits go.
I think I'll have to pass on this one. :)
When I was a teen with no training what so ever I made the entire series of oscillators (colpitts, armstrong, crystal,etc.) using coils made from toilet role tubes, single transistors, and other parts, most home made. I also made a huge numbers of receivers of various types. This was the time one of my Dad's favorite expressions to me was "Turn it off". It usually cleared the TV interference, so he wasn't far off.
Wendy
Joined Mar 24, 2008
23,421
Excellent. I think a total rewrite is in order though, basically scrap some of what we've done, add a reference to the Schottky to the crystal detector section, along with a rewrite of the history where appropriate (if appropriate).
The book still surprises, in a good way. Thanks Dennis.
