Adc
Discussion in 'General Electronics Chat' started by Mazaag, Aug 29, 2007.
  1. Mazaag
    Thread Starter Senior Member
    Oct 23, 2004
    255
    Hi guys,
    I'm looking at the data sheet for a ADC,
    ADC0804
    I just wanted to know what CS , WR , RD , and INTR mean... ? and how can I use them to be able to convert an incoming analog voltage at any rate.
    Thanks guys​
  2. Dave
    Retired Moderator
    Nov 17, 2003
    6,960
    145
    CS - Chip select
    WR - Write
    RD - Read
    INTR - Interrupt
    Can you link to the datasheet?
    Dave
  3. Mazaag
    Oct 23, 2004
    255
    http://esd.cs.ucr.edu/labs/general/ADC0801.pdf
    Why do we have both read and write ? I can understand why we have a read ( as in read in the digital value ) , but why is there a Write , and what is Interrupt... I don't think it explains it at all in the datasheet
  4. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    The ADC804 data sheet does not appear to use any of those signals. It's a serial output converter. You give it a convert command, and clock in the result of the conversion.
  5. nanovate
    Distinguished Member
    May 7, 2007
    665
    Take a look at page 5 for the timing diagrams which show the order the signals need to be asserted. Page 8 also shows some example configurations. This operates much like an external memory interface.
