1. teesuni11
    Feb 21, 2011
    hello, has anyone got any circuit designs on 8-bit ADC circuits tht you can show me as i have been searching for hours but have had no luck. It has to provide parrallel TTL compatible logic, and in the range of 0-5 volts DC. Also 8 LED's to display the binary output code.
    any help will be much appreciated
  2. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
  3. GetDeviceInfo
    Jun 7, 2009
    1,571
    230
    it's called parametric search and is available through many of the major suppliers.
  4. t06afre
    May 11, 2009
    5,939
    1,222
    Many micro controller units (MCU) do have 10 bits ADC on board. It will do your task quite simple. As your problem will mostly be transferred from a hardware problem. To a a software problem. It is just a tip:) It may not be appliable on your project.
