ADC
Discussion in 'The Projects Forum' started by Cerkit, Feb 9, 2009.
  1. Cerkit
    Thread Starter Active Member
    Jan 4, 2009
    275
    Hi. Not sure how to operate a TLC540I. What signal do i need to tell it to start sampling data? Also once data is sampled will it be at the output automatically or do i need another signal to enable the data out??
  2. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    It's an interesting critter. It somewhat appears from the data sheet that once you have pulled chip select low and selected a multiplexer channel, using the I/O clock and the address input line, then the system clock will agitate the internals and do the conversion.
    It also appears that the I/O clock will step the conversion out after chip select has gone high, but only after the conversion has taken place.
    Page 9 of the data sheet is where the process gets explained.
