ADC
Discussion in 'The Projects Forum' started by Cerkit, Jan 13, 2009.
  1. Cerkit
    Thread Starter Active Member
    Jan 4, 2009
    275
    Hi. Does anyone know an ADC I could use for a voltmeter module. Looking for a fairly cheap one. Don't know models. Need it to measure voltages up to 12 volts.
  2. mik3
    Feb 4, 2008
    4,846
    63
    Will you like one with serial or parallel output?
    What is the smallest change in voltage you will like to measure?
  3. jj_alukkas
    Distinguished Member
    Jan 8, 2009
    751
    5
    Need an ADC chip?? Try ICL7107
  4. jj_alukkas
    Jan 8, 2009
    751
    5
    It works with seven segment displays and has a good resolution
  5. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    Or get a panel meter and make up a resistive divider.
  6. Cerkit
    Jan 4, 2009
    275
    Serial output. At least a change of 0.01 volts.
  7. mik3
    Feb 4, 2008
    4,846
    63
  8. Cerkit
    Jan 4, 2009
    275
    Also I need it to have a very high sampling frequency because I will need it to sample a signal which could be potentially as high as 50khz. therefore will need it to sample at least at 25khz. Is something like that availabe??
  9. mik3
    Feb 4, 2008
    4,846
    63
  10. jj_alukkas
    Jan 8, 2009
    751
    5
