Adc with ssd driver
Discussion in 'The Projects Forum' started by Akeel, Nov 24, 2013.
  1. Akeel
    Nov 24, 2013
    Hi I want to design 3 digit 7 segments display that can measure voltage by converting analog voltage to display, is there a single chip that can
    convert the analog input voltage to its equivalent digital value then output it (serially) to a three digits 7 segments display (what is the number of such 3digits 7 segments display that can receive serial input). Thanks.
  2. MikeML
    Oct 2, 2009
    5,451
    1,066
  3. crutschow
    Mar 14, 2008
    13,501
    3,375
    The ICL7106 is a 3 1/2 digit A/D that drives 7-segment LCD displays. The similar ICL7107 drives 7-segment LED displays. Take your pick.
    They both have direct parallel out to the display, however. Why do you want serial out?
