ADC with 16f877a
Discussion in 'Embedded Systems and Microcontrollers' started by Alicp, Mar 12, 2014.
  1. Alicp
    Mar 12, 2014
    7
    hello can you help about this source code(in image) the result not display
      File size:
      176.2 KB
      55
      File size:
      198.4 KB
      39
  2. ericgibbs
    Jan 29, 2010
    2,575
    389
    hi,
    Does the label 'Value' appear on the LCD.?
    What Xtal frequency have you set.?
  3. Alicp
    Mar 12, 2014
    7
    the label 'Value' not appear on the LCD.
    freq=8MHZ
  4. tshuck
    Oct 18, 2012
    3,531
    675
    Without knowing about, or having ever used, MikroC, there is probably another routine for initializing a LCD in 4 bit mode (the initialization sequence is different).
    Other than that, can you view the ADC result when you run the simulation in debug mode?
    Have you verified the LCD is working?
    In a side note, I think that these simulators can do you a real disservice as it allows you to run code in a PIC without a clock.
  5. Alicp
    Mar 12, 2014
    7
    exist a loop in L_Delay_5500us3
    L_Delay_5500us3:
    0x0013 0x0BFD DECFSZ R13, 1
    0x0014 0x2813 GOTO L_Delay_5500us3
  6. t06afre
    May 11, 2009
    5,939
    1,222
    First make sure your LCD functions work. Start with writing a program that write "hello world" on the LCD Before such a program works it is no point in going further. Then write a simple routine that convert the the 12 bit ADC value to a ASCII format number and use the working LCD routine to dump latter ADC ASCII number on the LCD
    THE_RB likes this.
  7. tshuck
    Oct 18, 2012
    3,531
    675
    Yes, a blocking delay will use a loop.
    Agreed, but a small point - it's a 10-bit ADC...
  8. Alicp
    Mar 12, 2014
    7
    lcd work but adc_read(); don't work
    can any one give me an example on adc with pic16f877a with source code since i'm beginner in microcontroller?
  9. tshuck
    Oct 18, 2012
    3,531
    675
    You will need to set the ANSEL and comparator registers for the analog functions to work.
    See here.
  10. ericgibbs
    Jan 29, 2010
    2,575
    389
    hi,
    You said in post #3, that the 'text label= value' is not being displayed, so the LCD is not working.
    Can you post the full hex code?, I do not use MickroC
  11. Ian Rogers
    Member
    Dec 12, 2012
    158
    29
    Look at your 12 messages!!!!! You'll find that MCLR needs to be connected to 5v rail!!
  12. t06afre
    May 11, 2009
    5,939
    1,222
    @Alicp
    As a beginner it could be smart to always include this code in your program
    Code ( (Unknown Language)):
    1.
    2. ANSEL  = 0x00;              // Configure all pins with ADC option
    3. ANSELH = 0;                 // as digital I/O
    4.   C1ON_bit = 0;               [I]// Disable comparators[/I]
    5.   C2ON_bit = 0;
    6.
    7.
    And if you need analog input rather set the needed bit in the corresponding ANSEL(H) register bits separately. By default after a reset pins with ADC input function are configurated as analog input NOT digital IO
  13. Alicp
    Mar 12, 2014
    7
    :02000000d52cfd
    :10000600033083120313fd00fd0b072800000000d8
    :020016000800e0
    :020018000800de
    :10001a00023083120313fc00c830fd00fd0b1328c5
    :06002a00fc0b1328080086
    :0e003000f201f101f001f801f30100300800c7
    :10003e0083120313dd1b25288711262887155d1bc8
    :10004e002a2807112b280715dd1a2f28871030288c
    :10005e0087145d1a34280710352807143a183928e2
    :10006e0006143a28061086140c208610dd19412835
    :10007e008711422887155d1946280711472807154d
    :10008e00dd184b2887104c2887145d185028071050
    :10009e00512807143a1855280614562806108614a7
    :1000ae000c2086103a1c5d280d205e2803200800c7
    :1000be007b15fb1f69280130f300f201f101f001fd
    :0800ce00fa0df20cff300800ee
    :0800d600fa1ff21300300800cc
    :1000de00fb14fb1f7928ff30f300f200f100f00053
    :0800ee00fa0df20cff300800ce
    :1000f600831203135b08f2007208f100f20a5c082f
    :10010600f000dc0a700884000008f0007108840022
    :1001160070088000710884000008031993287f285e
    :060126005b08f000080078
    :10012c0083120313fb017308031d77080319ed28d1
    :10013c0072087606fa007708f3077e30031caa28ab
    :10014c00f3020318f028ad28f302031cf3287208fd
    :10015c00f8007108fc007008fd00f817f617031082
    :10016c00f201f101f0011830a0007d1cc7287408c1
    :10017c00f00775080318750ff10776080318760f4a
    :10018c00f207f20cf10cf00cf80cfc0cfd0c03104b
    :10019c00a00bbb28f21bd728f80df00df10df20dba
    :1001ac00f3037b1b701ce928f81fe928f00a0319dc
    :1001bc00f10a0319f20a031de928f20cf10cf00cf8
    :1001cc00f30a0319f028fa1ff2130030f528013056
    :1001dc001820f52802306f20f52804305f2000002d
    :0201ec00080009
    :0e01ee000000000000000000000000000800fb
    :0e01fc008312031333088a00320882000800c1
    :10020a00a0017208031d1a297108f2007008f10092
    :10021a00f001a0157208031d1a297108f200f101f4
    :10022a00a01120167208031928292008f302031db9
    :10023a00031c2c290310f21b3029f00df10df20dcd
    :10024a00f30b20292c290130fc0018203329023015
    :0e025a00fc005f2033290430fc006b200800fc
    :1002680083120313fa017308031d7a147708031d18
    :10027800fa147a0803198029033a03194b297a18c2
    :100288004829f61f7e297c29f21f7c297e297208bd
    :100298008039fa00f21376088039f6137a060319c2
    :1002a80059297a0803197c297e29770873020319ca
    :1002b8006029031c742978297608720203196729b2
    :1002c800031c742978297508710203196e29031c07
    :1002d8007429782974087002031980290318782969
    :1002e800fa0803197e297c29fa0803197c297e2932
    :1002f800031408000310080003140315080008007d
    :10030800831203133a105b08dd001f203a1408001b
    :1003180083120313f8010830fc00700df80d7408ff
    :10032800f80203189929f8070310f00dfc0b91291e
    :020338000800bb
    :10033a0083120313d901da014e08d5004f08d600fb
    :10034a005008d7005108d8005808ff3a031db729aa
    :10035a005708ff3a031db7295608ff3a031db72964
    :10036a005508ff3a031dc1295208db002730dc007b
    :10037a007b200330f000962b0130d300d71fd02901
    :10038a0080305706f0007008d700d30a520884005c
    :10039a002d308000d20a0030f0005806031ddf29f4
    :1003aa0070085706031ddf2970085606031ddf294a
    :1003ba005508003a031de8295208db002530dc0005
    :1003ca007b20f001962b5808ff3a031df62957089f
    :1003da00003a031df6295608003a031df629550866
    :1003ea00003a031d002a5208db002130dc007b2082
    :1003fa005308f000962b0030f4000030f50000306e
    :10040a00f6007f30f7005508f0005608f10057084b
    :10041a00f2005808f3003421013003180030f000cc
    :10042a0070080319332a5508f0005608f1005708d6
    :10043a00f2005808f3000030f4000030f5002030d4
    :10044a00f6008230f70096207008d5007108d600b1
    :10045a007208d7007308d800da03002a0030f400c3
    :10046a000030f5002030f6008230f7005508f00021
    :10047a005608f1005708f2005808f30034210130f9
    :10048a00031c0030f00070080319662a5508f000b2
    :10049a005608f1005708f2005808f300cd30f4006e
    :1004aa00cc30f5004c30f6007b30f700962070080f
    :1004ba00d5007108d6007208d7007308d800da0a86
    :1004ca00332aff305505f800ff305605f9007f3012
    :1004da005705fa0000305805fb007808f40079083f
    :1004ea00f5007a08f6007b08f700f40df50df60d15
    :1004fa00f70d741000305505f00000305605f10074
    :10050a0000305705f200ff305805f3007008d50097
    :10051a007108d6007208d7007308d8007408550409
    :10052a00f00075085604f10076085704f2007708bf
    :10053a005804f3007008d5007108d6007208d70075
    :10054a007308d8007f305802f0007008d4000130d8
    :10055a00d8007008f4005508f0005608f100570852
    :10056a00f2005808f30074080319c22af00df10dbd
    :10057a00f20df30d7010ff3eb92a7008d50071080c
    :10058a00d6007208d7007308d8005808303ef00029
    :10059a005208840070088000d20a80305a06f0009f
    :1005aa008030013a7002031ce32a8030063af000d8
    :1005ba0080305a067002031ce32aea2a5208840091
    :1005ca002e308000d20a0130d9000630d4005408f7
    :1005da00003a0319482bd8015508f0005608f100d3
    :1005ea005708f2005808f300f00df10df20df30d63
    :1005fa007010f00df10df20df30d70105508f007a3
    :10060a0056080318560ff10757080318570ff20731
    :10061a0058080318580ff3077008d5007108d60058
    :10062a007208d7007308d8005508f0005608f10080
    :10063a005708f2005808f300f00df10df20df30d12
    :10064a0070107008d5007108d6007208d7007308b8
    :10065a00d8005808303ef000520884007008800024
    :10066a00d20a5908003a031d462bda035a08003aff
    :10067a00031d462b520884002e308000d20a013016
    :10068a00d900d403ec2aff30520784000008303a1c
    :10069a00031d512bd203482bff3052078400000858
    :1006aa002e3a031d592bd2035a08003a0319922bea
    :1006ba005208840065308000d20a80305a06f00061
    :1006ca008030003a70020318722b520884002d30d1
    :1006da008000d20a5a08003cda005a08d4005a08a4
    :1006ea00093c0318842b0a30f4005408f0008c21ca
    :1006fa003030f0075208840070088000d20a0a30ad
    :10070a00f4005408f0008c217808f0003030f0072b
    :10071a005208840070088000d20a520884008001be
    :04072a00f0010800d2
    :10072e0083120313cf014f084e07840000080319ec
    :10073e00a82b4f084e0784000008db008421cf0a47
    :04074e009a2b0800da
    :1007520083120313fb01fa01f9018030f800f10c56
    :10076200f00c031cbd2b7408f90775080318750fec
    :10077200fa070318fb0a0310f01fc52b7408fa07c7
    :1007820075080318750ffb07fb0cfa0cf90cf80c33
    :10079200031cb02b7b08f3007a08f2007908f10001
    :0607a2007808f0000800d9
    :1007a800831203137008f8007108f000f101f201d8
    :1007b800f301fb01fc019630f300fa017008f10027
    :0c07c8007808f000f801f201052108009b
    :1007d40083120313f801f9011030fc00710df80db8
    :1007e400f90d7408f8027508031c750ff902031853
    :1007f400022c7408f80775080318750ff90703101d
    :0a080400f00df10dfc0bf02b0800c5
    :10080e00c330831203139f05c0309f004e08f000c3
    :10081e00f00d7010f00d701070089f0483169f1766
    :10082e0083121f14f7209f149f1c1f2c00001b2cdb
    :10083e001f101e08f100f00183161e08f004003090
    :04084e00f1040800a9
    :10085200ff3083120313bb00ff30bc00ff30bd002a
    :10086200ff30c3309f05c0309f0083169f1783124d
    :040872001f14080047
    :10087600fe208a110a128000840ab20a0319b30afa
    :08088600f003031d3b2c0800e8
    :10088e0083160313861006100710871007118711a1
    :10089e0083128610061087110711871007100d207e
    :1008ae000d200d208714071486140c2086100d20a1
    :1008be0086140c2086100d2086140c2086100d2018
    :1008ce00071086140c2086100d2086140c2086101e
    :1008de008710871586140c2086100d20871107149b
    :1008ee0086140c208610071086140c2086100d20fe
    :1008fe0086140c208610071486140c2086100d20ea
    :10090e00071086140c2086108715071587140714f8
    :0c091e0086140c2086100d203a140800ee
    :10092a00a72c803083120313ce00ba2cc030ce001d
    :10093a00ba2c9430ce00ba2cd430ce00ba2c8030e7
    :10094a00ce00ba2c831203134e08013a0319962ccf
    :10095a004e08023a03199b2c4e08033a03199e2c9f
    :10096a004e08043a0319a12ca42c4f03f0004e0898
    :10097a00f0077008ce007008dd001f203a10d10180
    :10098a0051085007840000080319d32c5108500756
    :10099a0084000008db008421d10ac52c3a1408001f
    :1009aa004225ff30831603138500472429240317a1
    :1009ba00871388130c300313dd001f200230ce008a
    :1009ca00072470088312b8007108b9000530f400d2
    :1009da000030f500a923ff30f4000330f500ea23c4
    :1009ea00d4237008b4007108b5007208b600730801
    :1009fa00b7007008ce007108cf007208d0007308e3
    :100a0a00d1003e30d2009d210130ce000330cf000c
    :100a1a002b30d00095240230fb004530fc00a93071
    :100a2a00fd00fd0b162dfc0b162dfb0b162d0000e1
    :100a3a0000003e30ce0097232130fc007630fd00c6
    :0e0a4a00fd0b252dfc0b252d0000e32c2b2d84
    :100a840021308400113083120313f0003130b2009e
    :080a94000530b3003b2408000b
    :080a620049344e3446340034df
    :040a6a0030340034f0
    :080a6e004e3461344e340034b3
    :0e0a7600763461346c34753465343a340034af
    :04400e00d2200007b5
    :00000001ff
  14. Ian Rogers
    Member
    Dec 12, 2012
    158
    29
    Not on a pic16f877a you won't.... It hasn't got any ansel registers.... ADCON1 = 0x7;
    But that's not his problem... In ISIS he need to set MCLR pin otherwise it will not simulate...
  15. tshuck
    Oct 18, 2012
    3,531
    675
    1.)Put it in code tags! (The button that looks like"#" above your post's edit box - it surrounds your code with [CODE ] and [/CODE ] tags, minus the added spaces, so your post doesn't make the page gigantic)
    2.) Phrase put some context in your posts - explain why you are posting it and what it is for.
    3.) How did you verify the LCD works?
  16. tshuck
    Oct 18, 2012
    3,531
    675
    ... even with MCLR turned off in the configuration?
    So it will let you simulate without a clock, but a missing pull up breaks it?:confused::rolleyes:
  17. Alicp
    Mar 12, 2014
    7
    same problem no new
  18. Ian Rogers
    Member
    Dec 12, 2012
    158
    29
    MCLR is not configurable on the pic16f877a...
    The crystal is not simulated in ISIS....
    tshuck likes this.
  19. ericgibbs
    Jan 29, 2010
    2,575
    389
    hi Alicp,
    My program is reporting 'check sum errors' for your program listing, sorry I cannot run it.
  20. Ian Rogers
    Member
    Dec 12, 2012
    158
    29
    The initial jump location is to 0x4D5 but the hex line throws a CRC error.
    The code tries to access 0x107 and 0x108... not valid...
    The code is also displaying a CONFIG WORD2 again not from this chip... I suspect you have the wrong processor selected in your IDE!!
