1. well wisher
    Nov 23, 2012
    I programmed PIC 16F73,16F873,877 for ADC many times(interfaced LM35,voltage regulators).They worked well.Today I tried to program 877A,but not working.Not giving any output.I used the same code used for 877.From the datasheet I saw bit 6 of ADCON1 is used in 877A...Can anyone help me?
  2. ErnieM
    Apr 24, 2011
    7,439
    1,627
    No one can help given the limited information you supplied; "but not working" is not a description of the problem. Showing the schematic would be a plus. Showing how you set up the A2D is essential.
    Bit 6 of ADCON1 is ADCS2, the top bit of the ADCS setting and is used to control the clock source for the converter. The 877A A/D Conversion Clock Select bits are 3 bits long, not 2 bits as in the non-A version.
    I would suggest looking at the data sheet of the device you are actually using and program for that device rather then just copping code from another device.
