ADC measuring between VREF- and VREF+
Potato Pudding
Joined Jun 11, 2010
688
Before I put a lot of work into this can somebody give me a quick check answer regarding some PIC features.
Confirm that I can constrain the ADC measurements between VREF- and VREF+. I would like to use that to limit measurements to within a 1 volt range and need to know if doing that will give a full 10 bit accuracy across that 1 Volt of measurement so that in that range I will get measurements to the Millivolt.
Have I misunderstood the documentation? (PIC16f887 checking 16f88# family datasheet F version dated 2009).
I was expecting to set up a complicated external window amplifier to fill the normal 5volt input range from that 1 volt window to get a similar effect, until I looked at the PIC data again.
Markd77
Joined Sep 7, 2009
2,806
There is this table which suggests the error may be above 1 Lsb with 1 V.
There is no mention of Vref- in the tables, which isn't very helpful.
Potato Pudding
Joined Jun 11, 2010
688
Interesting.
So it doesn't say that it won't work as far as I can tell.
Minimum error is +-1least significant bit at 2.7 Volts so +-2.7 mV.
I think that it could still be worth locating that 5.4mV error bar with 1 mV accuracy if the min and max Vrefs work the way that I am thinking they do.
I am just worried that I am missing another meaning for them, and assuming they do something different than intended.
I searched the Vrefs in the PDF and none of the references for them seemed to show anything else.
I would not bother with an external amplifier. I can get a limit to a 2.5 Volts range located in the middle or even at the top end of the 5 Volts supply range and that will be plenty. If I really wanted more accuracy I would use a device with higher resolution ADC, and there are plenty of those to choose from.
Being able to locate my sample range where the input naturally falls is actually more important.
