ADC: kSPS
Discussion in 'General Electronics Chat' started by Management, Nov 23, 2009.
  1. Management
    Thread Starter Active Member
    Sep 18, 2007
    306
    I know what drives the N-bit choice of a ADC/DAC but what drives the samples per second spec on an Analog to Digital Converter?
    Thinking about using a AD7680. It's a 16-bit 100 kSPS ADC. An input range of zero to about 5.5 volts and the highest frequency of 2200 Hz.
  2. t06afre
    May 11, 2009
    5,939
    1,222
    It is the SCLK input the drives the conversion. 1 conversion takes 20 SCLK cycles. You can use 2.5 MHz as max SCLK frequency and 250KHz as min frequency.
  3. Management
    Sep 18, 2007
    306
    Did you take this from the datasheet?
    Thanks for the reply.
  4. t06afre
    May 11, 2009
    5,939
    1,222
    Yes it is all in the data sheet;)
  5. Management
    Sep 18, 2007
    306
    What if the CLK speed is much higher?
  6. t06afre
    May 11, 2009
    5,939
    1,222
    The clock speed, is specified by the manufacturer. So going outside these limits will produce erratic errors. I can not give you a more precise answer than that
  7. Ron H
    Apr 14, 2005
    7,050
    657
    According to the datasheet, SCLK minimum is 10kHz.
  8. t06afre
    May 11, 2009
    5,939
    1,222
    Not as I read it. But anyway the OP wanted the fast samplerate so it does not matter.
  9. blueroomelectronics
    Jul 22, 2007
    1,758
    98
    What are you trying to sample?
  10. Ron H
    Apr 14, 2005
    7,050
    657
    Turns out I was looking at a preliminary datasheet from datasheetcatalog.org.
  11. Management
    Sep 18, 2007
    306
    A 4-20 mA with HART Comm (1 mA peak to peak) riding on top of it at a maximum frequency of 2200 Hz running through a 250 Ohm sense resistor.
  12. kubeek
    Sep 20, 2005
    4,691
    806
    2200Hz or 2200MHz? thats a huge difference
  13. Management
    Sep 18, 2007
    306
    Sorry about that. It's suppose to read 2200 Hz.
