ADC dsPIC not working. Please help.
Discussion in 'General Electronics Chat' started by Electron_23, May 25, 2014.
  1. Electron_23
    May 6, 2014
    8
    Hello everyone.
    Im trying to use the ADC module of the dsPIC33ep512mu810, reading the potentiometer of the Explorar 16 board, and show the binary conversion in PORT A (LEDs). Up to now I did not have success and I don't know whats missing or wrong. Could someone help please?
    Code ( (Unknown Language)):
    1.
    2. //DEFINES or PARAMETERS
    3. #define FOSC 8000000 //OSCILLATION FREQUENCY
    4. #define PLL 1 //SETS PLL
    5. #define FCY (FOSC*PLL/2) //CYCLE FREQUENCY
    6.
    7.
    8.
    9. #include <stdio.h>
    10. #include <stdlib.h>
    11. #include <p33ep512mu810.h>
    12.
    13. //MACROS or CONFIGURATION BITS
    14. _FOSCSEL(FNOSC_PRI & IESO_OFF)
    15. // Primary oscillator as source
    16. // Start up with user-selected oscillator source
    17. _FOSC(FCKSM_CSDCMD & POSCMD_XT & OSCIOFNC_ON)
    18. // Both Clock switching and Fail-safe Clock Monitor are disabled
    19. // XT Crystal Oscillator Mode
    20. // OSC2 is general purpose digital I/O pin
    21. _FWDT(FWDTEN_OFF)
    22. // Watchdog timer enabled/disabled by user software
    23. _FPOR(FPWRT_PWR16 & BOREN_ON)
    24. // Power-on Reset Timer Value and bor enabled
    25. _FGS(GWRP_OFF & GSS_OFF & GSSK_OFF)
    26. // General Segment may be written
    27. // General Segment Code protect is disabled
    28. // General Segment Write Protection and Code Protection is Disabled
    29.
    30.
    31. // FUNCTION DECLARATIONS
    32. void adc(void);
    33. void delay_ms(long ms);
    34.
    35.
    36. /*
    37.  *
    38.  */
    39. int main() {
    40.     TRISA = 0;
    41.     adc();
    42.
    43.     //loop to sample and acquire data
    44.     while(1){
    45.         AD1CON1bits.SAMP = 1;   //sampling
    46.         delay_ms(10);            //sample time
    47.         AD1CON1bits.SAMP = 0;   //holding
    48.
    49.         while(!AD1CON1bits.DONE);   //is the conversion done?
    50.         PORTA = ADC1BUF1;  //data is shown in port A (LEDs)
    51.     }
    52.
    53.     return (EXIT_SUCCESS);
    54. }
    55.
    56.
    57.
    58. void adc(void){
    59.
    60.     ANSELA = ANSELB = ANSELC = ANSELD = ANSELE = ANSELG = 0x0000;
    61.     // Set ports A, B, C, D, E, G as I/O digital ports.
    62.     ANSELBbits.ANSB5 = 1;  //makes AN5/RB5 analog input.
    63.
    64.     AD1CON1bits.AD12B = 1; // Sets 12 bits ADC.
    65.
    66.     AD1CON1 = 0x0000;
    67.     AD1CON2 = 0x0000;
    68.     AD1CON3 = 0x000F;
    69.     AD1CON4 = 0x0000;
    70.     AD1CHS0 = 0x0005;
    71.     AD1CHS123 = 0x0000;
    72.     AD1CSSH = 0x0000;
    73.     AD1CSSL = 0x0000;
    74.     AD1CON1bits.ADON = 1;  //enables ADC
    75.     delay_ms(10);
    76. }
    77.
    78.
    79.
    80. void delay_ms(long ms){
    81.
    82.     T1CON = 0;   //reset timer
    83.     TMR1 = 0;    //load timer count register to 0
    84.
    85.     IPC0bits.T1IP = 1; // interrupt priority count
    86.     PR1 = ((FCY/256)*ms)/1000; //20ms delay. Comes from (((Fosc/4)/prescaler)*20ms)/(1000ms)
    87.     IFS0bits.T1IF = 0;
    88.     IEC0bits.T1IE = 0;
    89.     T1CON = 0X8030; //hexadecimal of 1000000000110000
    90.     // which means start the timer and select 256 prescaler
    91.     while(IFS0bits.T1IF == 0);
    92.
    93. }
    94.
    95.
    Thank you very much in advance.
  2. THE_RB
    Feb 11, 2008
    5,435
    1,305
    I don't use that chip, but in 90% of cases the reason a PIC ADC is not working right is becuase it has not been configured right. :)
    That also includes the port pins configuration, if some other hardware feature has taken over the pin and forced it to be an output or force it to another function.
