ADC calibration
Discussion in 'General Electronics Chat' started by yagyasen, Jun 19, 2013.
  1. yagyasen
    Jun 18, 2013
    11
    what is the meaning of digital"calibration" of ADC ? I mean how digital calibration of ADC is done?
  2. kubeek
    Sep 20, 2005
    4,687
    805
    You input known inputs ino the ADC and note what values it gives you.
  3. yagyasen
    Jun 18, 2013
    11
    Thanks,
    while reading a paper on digital Calibration and Testtime Reduction on ADC i came across the following line :-
    " longer test sequence required to accumulate sufficient information about circuit non idealities result in longer calibration time for digitally calibrated devices."
    Can you please tell what is the meaning of CIRCUIT NON IDEALITIES?
  4. kubeek
    Sep 20, 2005
    4,687
    805
    For example the response could be slightly off from linear, so if you draw a line between the top and bottom values, the ones in the middle could be a bit off. Other things could be noise and stability of the readings.
    yagyasen likes this.
  5. ErnieM
    Apr 24, 2011
    7,435
    1,625
    The two major CIRCUIT NON IDEALITIES are offset voltage and gain errors.
    One can perform a digital calibration by applying a known very small and a known very large input signal. By assuming a linear response*, and using the ADC output along with these two known points the transfer function can be computed.
    * where the output y = mx + b of input x
