Thank you ErnieM. Don't dig it upI've done it. Worked just fine.
I forget which exact PIC it was (I can dig it up later if you need it) but both an A2D channel and a comparator shared the same pin.
Neither knew the other was also looking at the same signal, and they worked together. I believe it was a (slow) current reporting mechanizm along with a (fast) trip circuit.
I stand corrected.I've done it. Worked just fine.
by Aaron Carman
by Jake Hertz
by Jake Hertz
by Jake Hertz
