adc 0808
Discussion in 'The Projects Forum' started by sirish, Apr 11, 2006.
  1. sirish
    Apr 5, 2006
    How to use Adc 0808 with a pc parallel port.
    to convert analog voltage to digital.
  2. Murod
    Dec 24, 2005
    30
    Please read the manual of ADC0808 and PC Paralel Port. Have You tried to find on the internet?
    Best Regards,
    Hasan Murod.
  3. thingmaker3
    Retired Moderator
    May 16, 2005
    5,072
    6
    Do you wish to use all eight inputs, or just one? If just one, connect pin one of the port through an inverter to pin seven of the chip, and pins 8, 14, 15, and 17 through 21 of the chip through inverters to pins 2 - 9 of the port. (Pay attention to MSB and LSB - pins on the chip are not in order of bits.) The inverters are needed because the port uses hardware inversion.
  4. firmanardha
    May 21, 2007
    to convert analog voltage to digital?
  5. shakthi shree
    Jan 16, 2009
    WE WANT ABOUT ADC 0808 - PIN DETAILS
    AND WANT TO KNOW HOW INTERFACING IS INTERFACED WITH PC WITH HELP OF A NON INVERTING BUFFER
  6. thingmaker3
    Retired Moderator
    May 16, 2005
    5,072
    6
  7. ambu
    Apr 18, 2009
    thanksssssssssssssssss
  8. ambu
    Apr 18, 2009
