Adapter Voltage help!!
Discussion in 'General Electronics Chat' started by kahafeez, Oct 2, 2010.
  1. kahafeez
    Thread Starter Active Member
    Dec 2, 2008
    150
    Hello everyone!
    I have a device that works on 12V/ 1A. Its adapter is not working anymore. I have another adapter which is 16V/ 1A. i need to confirm if i can power up my device using the 16V supply. will it hurt my device or can i use it?
    the device is a WiFi access point so i will need it to be switched on 24/7. Please suggest.
  2. dokworm
    Oct 1, 2010
    5
    No, do not use the 16V adapter, it will most likely kill it. You could use a 12V adapter, as long as it is at least 1A. (i.e. a 12V 2A will work, as would a 12V 3A, but not a 12V 500milliamp).
    You may want to check if the 12V supply you currently has says it is 'regulated', and if so, only use another regulated supply.
    You could make a voltage regulator circuit to cut the 16V down to 12volts I guess, but you would be better off obtaining a new supply. I often check out op-shops and pick up supplies for next to nothing.
  3. retched
    Dec 5, 2009
    5,201
    313
    12v wallwarts should be a dime a dozen pretty much everywhere in the world.
    As dokworm mentioned 16v most likely will kill your device.
    IF your device has a variable input, it may work.
    If you can read on the device something that says:
    Input 11vDC - 18vDC 1 Amp
    Then you would be ok. If it says 12vDC only.. then get yourself another adapter.
  4. kahafeez
    Dec 2, 2008
    150
    thank you. i will buy a new 12V supply :)
  5. marshallf3
    Jul 26, 2010
    2,358
    201
    Do what I do on occasion.
    Hit up garage sales and thrift shops when you drive by one and have a few free minutes, you'll usually find all sorts of orphaned supplies they're willing to sell for 50 cents.
    Granted - I've had to change quite a few ends on them but Radio Shack keeps those around, I've also come up with some strange voltage output supplies (sometimes multiple voltages) but I toss them into my box of them anyway as you never know.
