Adapt wireless doorbell to a wired one
Discussion in 'The Projects Forum' started by ViXoZuDo, Jul 6, 2016.
  1. ViXoZuDo
    Jul 6, 2016
    6
    Well, right now, I have a wired doorbell in my house (1st floor), but the problem is that in my 2nd floor, most of the times you can barely hear it. I don't want to wire it to 2nd floor, so I was thinking about a wireless system.
    I was looking online and I came up with the idea of buying a wireless doorbell that use a 12V battery and "short circuit" the bell push so it's always in the "ON" position. Adapt a 220V to 12V transformer to my already installed wired doorbell so it power the wireless switch and because it's always in the ON position, as soon as there is current to the wired one, the wireless switch will trigger and activate the wireless receiver in the 2nd floor.
    Here is the thing, I'm not an expert in electronics, so I don't know if this gonna work or I'll end up burning the wireless transmitter (push switch).
    So, tell me if this gonna work or I should do something else.
    PS: Diagram attached
  2. #12
    Nov 30, 2010
    16,663
    7,307
    Some difficulty with the diagram. The transformer is labeled "DC220V to AC12V".
    There is no such thing as a DC transformer.
    The "wired bell push" seems to be providing 220V to "220V wired door bell".
    Let's start with a different drawing and see if we can get some ideas working.
  3. DGElder
    Member
    Apr 3, 2016
    347
    87
    A mains 220V doorbell circuit! Are you sure about that?
    In what country is that within code?
  4. ViXoZuDo
    Jul 6, 2016
    6
    Ops, sorry, it's a AC 220v to DC 12v.
    Also, the Wired one is 220v. I don't know if internally have any kind of transformer.
  5. #12
    Nov 30, 2010
    16,663
    7,307
    I think you can bet it has a transformer. There is no legal (or safe) way to put 220V on a door bell button.
    Go investigate.
  6. ViXoZuDo
    Jul 6, 2016
    6
    I don't know about other countries, but here it's pretty common to have 220v direct to the door bell button and it's legal. It's like having a light switch. There is not much science behind it.
    It's something like this: http://www.aliexpress.com/item//32352979999.html
    You have current, it sounds...
  7. #12
    Nov 30, 2010
    16,663
    7,307
    And we don't know about your country because you haven't told which one it is.
    Wait. I'm beginning to understand. The bell is wired directly to 220VAC with unlimited power. That is very illegal in many countries.
  8. ViXoZuDo
    Jul 6, 2016
    6
    Yep, 220VAC in the door bell button. My house was constructed from 0 and I know where is all the wiring.
  9. #12
    Nov 30, 2010
    16,663
    7,307
    I think this is what you're looking for:
  10. ViXoZuDo
    Jul 6, 2016
    6
    So I should use a 12v relay and forget about powering direct the wireless button? There is something else?
    and thanks in advance :)
  11. #12
    Nov 30, 2010
    16,663
    7,307
    It seems to me that the wireless door bell wants a push button. The relay will accomplish that function with a minimum of complications.
    If the wireless door bell wants 220VAC and you try to control that with a push button, the wireless door bell will only be powered for less than 1 second. Better to give it all the 220VAC power it wants and just add a fake push button.
    Marcus2012 likes this.
  12. Marcus2012
    Member
    Feb 22, 2015
    349
    26
    Yeah this was what I was writing lol. Use a relay on the mains doorbell switch line to control the wireless switch. Just hack into something like this and use the relay for the switch. Add 3VDC (or whatever voltage) used from mains or use batteries at your discretion for the wireless transmitter.
    Cordless /Wireless Plug In /AC Main Socket Door bell/ 16 Melody Chime 80m Range
  13. DGElder
    Member
    Apr 3, 2016
    347
    87
    Nothing speaks safety like a $3.92 high voltage Chinese doorbell.:eek:
  14. ViXoZuDo
    Jul 6, 2016
    6
    Actually, the wireless door bell button I find use a 12V battery. It's not wired anywhere. Anyway, the idea of constant current and a relay seems a better idea.
    Thanks. I'll update with the results. (In a month or so because It's cheaper to import form china the electronics I need).
