AD741 Replacment
Discussion in 'General Electronics Chat' started by alecjcook, Mar 1, 2014.
  1. alecjcook
    Jan 2, 2014
    5
    I am currently simulating a circuit using AD741s (12V). I am trying to modify this circuit to work at a different voltage (36V). Because of this I need to change this part to handle the extra voltage. I can not see what is wrong with the TLC2272 as a replacement, but when I swap in this part I my simulator, my circuit stops working (even at the original voltage).
    What am I missing? how is the operation of this part different?
  2. shteii01
    Feb 19, 2010
    3,500
    511
    Supply voltage is +8 and -8 volts. You probably fried it with 36 volts.
  3. paulktreg
    Distinguished Member
    Jun 2, 2008
    621
    124
    I may be reading the spec sheet wrong but isn't the maximum supply voltage for the TLC2272 + or - 8V?
    alecjcook likes this.
