AD713, quad op amp help
Discussion in 'The Projects Forum' started by kahafeez, Dec 3, 2008.
  1. kahafeez
    Thread Starter Active Member
    Dec 2, 2008
    150
  2. mik3
    Feb 4, 2008
    4,846
    63
    If you are doing to use them as inverting amplifiers, you can add another resistor on the inverting input and create a summing amplifier. Then use a potentiometer to adjust the voltage on this resistor, when the input signal resistor is tied to ground, as the output to have zero volts.
    What are you going to do with these op amps?
  3. kahafeez
    Dec 2, 2008
    150
    i actually was using alot of amplifiers in my project so i thought that instead of using single amp ic i should use something that contains more than one ic so that i could get rid of the power supplies to all.....
  4. mik3
    Feb 4, 2008
    4,846
    63
    Ok but what these op amps will do?
  5. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    If you need a trim, you are almost stuck with singles. Or find better op amps that don't have offset problems so you don't need trimming.
  6. Wendy
    Mar 24, 2008
    20,772
    2,540
    Many cases you don't even need to null it, let's see the schematic...
